the target bar keeps moving when i update
Mark Bandong
User offline. Last seen 3 years 19 hours ago. Offline
I’m new to p3 and i need help. Here’s my problem: After i made the baseline program(TP5A), i made a copy (PU01) as a program for update or current program. After copying the program i opened the newly created program (PU01) and i set TP5A as the target program (tools>project utilies>targets). I’ve done this in my trial program and it worked, meaning the target program is not moving everytime i update the current program. But now, everytime i update, the target bar is the same as the bar of the current program. I am very confused on what i have done. i followed the steps but it doesn’t work. what did i do wrong. Please help me if you have any suggestions. thanks.
Mark Bandong
Thanks steven!I’ll keep that in mind.God bless!
Mark Bandong
Johny! Thanks a lot! your my saviour. It worked. God bless.
Johny Kesserwany
User offline. Last seen 7 years 41 weeks ago. Offline
Go to Format/Bar and select your Target Bar than click on ’Modify’ on the ’Structure tab’
Structure
Type: Select the data type for the start and end points. Choose target1 Early start & target1 Early Finish.
It should work.
JK
Steven Oliver
User offline. Last seen 11 years 50 weeks ago. Offline
Make sure that you specify that the target bar is to be drawn based upon the Target Plan.
