Does Primavera Project Planner 3.1 work on Vista
Robin Jongen
User offline. Last seen 17 years 15 weeks ago. Offline
Does any one know if P3.1 works on Vista and if how.
regards,
Martyn Davies
User offline. Last seen 2 years 17 weeks ago. Offline
I have P3 running on Vista Ultimate and on Windows XP on Virtual PC 2007 on the same PC ie. a dual operating system. Virtual PC 2007 is a free download from Microsoft.
To run P3 from Vista is quite straightforward
1. Install P3 as normal accepting default paths etc.
2. Put an P3 icon on the desktop.
3. Right click on the P3 icon and select properties
4. Select the COMPATABILITY tab
5 Check the "Run this progam in compatibility mode for" box
6. Select "Windows XP (Service Pack 2)" in the drop down menu
7. Click on Apply
You should now be able to run P3 without any problems.
To run under a virtual PC is lot more involved.
Ronald Winter
User offline. Last seen 4 years 9 weeks ago. Offline
There are a couple of issues to be aware of.
1) Don’t install it in the "C:\Program Files" directory or you cannot access your report files. Use the default C:\P3WIN directory.
2) Vista does not support ther .HLP help file extension used by P3, so your help files will not work.
3) MS Office 2007 no longer supports the .WK1 spreadsheet format. Stick with MS Office 2003 or switch over to using the database file output option.
Good luck!
Ronald Winter
James Barnes
User offline. Last seen 2 years 7 weeks ago. Offline
I believe official policy from Pv is that they have tested it on vista 32 bit and it works but they won’t support it and that it won’t run on Vista 64bit, however that data may have changed in the last few months.
Rajeev Nelliyodan
User offline. Last seen 9 years 10 weeks ago. Offline
Yes as per Primavera. They have not find any issues.
