Activity ID and Exclusive
moutaz aldeib
User offline. Last seen 3 years 5 weeks ago. Offline
Dear all,
It’s well known that when you build a new schedule by using a new form, p3 takes you to the normal page of schedule to build your schedule, you start with Activity ID, but when you want to edit the activity ID, you should close the page and open again then tick "exclusive", is there any simple way you can edit the activity ID without closing the page and open it again.
Moutaz
A D
User offline. Last seen 4 years 1 week ago. Offline
Yes absolutely,
In a multi user environment, you will have the exclusive access.
I forgot to mention in my previous mail.
Raviraj A Bhedase
Ife Olyke
User offline. Last seen 10 years 23 weeks ago. Offline
Raviraj,
I suppose in a multiple user environment,changing ExclForActIDEdit value from 1 to 0 will show you as exclusive all the time, which implies that other users will not be able to make changes to the plan. Am I correct?
Frank:
Thanks for pointing out that copying and pasting will leave you with duplicate activities. You know we all have our different ways of doing these things… There is no undo command in P3, so I like copying and pasting, then going back to delete the old activity; that way, I keep track of my activities and can trace back any error. Also checking the box for pasting external relationship..
Ifeanyi
A D
If u r frequently editing the activity ID, then do this
Open windows folder in the main drive (C:)
open P3.ini file in the windows folder
Search for
ExclForActIDEdit
In the value, if it is 1, change it to O.
Evertime you will open P3 after that, you dont require to check on Exclusive box. By default it will take exclusive.
If you dont want, then simply change the value to 1.
Hope this is much easier.
Raviraj A Bhedase
Frank Borcherdt
User offline. Last seen 7 years 49 weeks ago. Offline
Copy and paste leaves the original activity ID in your schedule ie activity is now duplicated. Use cut and paste and check the box for external relationships to effectively change the Activity Id without duplication.
HTH
Frank Borcherdt
Ife Olyke
Hi Moutaz,
Follow these steps,
Select the activity ID,
Hold down Ctrl key and Press "C"
Hold down CTRL key and Press "V"
Rename Duplicates
Edit the Activity ID
OK
I hope this helps. Cheers.
Olyke
