P6 v7 Opening Project in Exclusive Mode (Grayed Out)
Will R
User offline. Last seen 11 years 29 weeks ago. Offline
I have a project stuck in "shared" mode.  The "exclusive" mode option is not available though I am using a stand alone version of P6 v7.0 as an admin with full access. This is the only project with this issue.  I have tried all forms of logging out, shutting down, re-booting etc.
Question - How do open this project in shared mode?
Andrew Moriarity
User offline. Last seen 2 years 13 weeks ago. Offline
The way we were able to fix the problem was to export the project and re-import it back in.  The options to open it in anything but Read Only were grayed out.
Thanks for the suggestion guys.
Mark Baguley
User offline. Last seen 6 years 32 weeks ago. Offline
Andrew,
It’s a bit like Arend’s suggestion but I’d try opening it in read only then making a copy. It happened to me ages ago but I can’t remember how I got over the problem (or in to it for that matter!). It’s a bit of a lame suggestion but I hope it helps.
Mark.
Andrew Moriarity
Will,
I am hving the same problem, did you ever figure out a solution to this problem?
Arend Woltjer
User offline. Last seen 8 years 39 weeks ago. Offline
Hi Will,
i suppose you mean that you want to open the project in exclusive mode. I can not help you except for a few suggestions;
Have you tried copy-paste the project to another eps node, checked the status; active /inactive/what-if
Is it maybe checked out?
Try an export to P3 and see what you can do there...
I hope you find the defect.
Arend
