Locking the filter!!!!!
Siva Kumar
User offline. Last seen 5 years 41 weeks ago. Offline
Hello all,
Is it possible to lock the filter in p3 programme files?.
Thnx & Regards
CSK
Bijaya Bajracharya
User offline. Last seen 8 years 29 weeks ago. Offline
A little more information.
In "Open a Project" window you will see three buttons- Oveview, Option and Access at the bottom. Just click Access. Now you can make necessary change. Read Write for yourself and Read Only or Restricted for EVERYONE. (ALL OTHERS is the term in other programme).
Bijaya Bajracharya
It is more to do with the access control. If not already done, using NETSET assign username (and password) for yourself in P3. Make you the OWNER of the project (i.e, you have full access). Add the ALL OTHERS eith READ ONLY access. This way nobody except you can change your filter setting.
Siva Kumar
Thanx Bijay.
Its Working..
shiva
Siva Kumar
karim
sorry i didnt mean to say abt saving the layout..
this is about locking the filter...so that others cant run the filter...
csk
Karim Mounir
User offline. Last seen 10 years 13 weeks ago. Offline
After applying the filter save the layout (view--> layout--> save as).
HTH
