Restore from P3 to P3e
7 replies [Last post]
salah obaidi
User offline. Last seen 13 years 27 weeks ago. Offline
Hi evryone...
Whenever I want to RESTORE Data From P3e to P3 Would that Cause any change in original data..(contractor Schedule)..?
Thank you for advise.
User offline. Last seen 2 days 18 hours ago. Offline
There is a utility for converting P3 to XER and XER to P3:
Prim73486
P3Converter.zip
Also remember P3 is a 16 bit application so it is limited to read 64 characters file names and 8 characters per subdirectory. Try copying your files into a folder with an 8 or less characters name, move the folder to your P# projects folder and try again.
Saleh Nabulsi
User offline. Last seen 13 years 12 weeks ago. Offline
How can I open an XER file in P3? is there a tool to convert. I have only P3 on my computer
Marcio Sampaio
User offline. Last seen 11 years 51 weeks ago. Offline
The big difference i can see is that i can convert a .xer into a P3 files without have to open project.
And u can convert P3 files into a .XER without have to import the file.
I dont know why Primavera hides this tools ins this location ... but i use it a lot.
Regards.
Karim Mounir
User offline. Last seen 10 years 2 weeks ago. Offline
Thanx Marcio, This is a great tool, but is their any difference between this tool and the normal "Import/Export" function in P5, and may i also ask why Primavera hides this tool in this location??
Marcio Sampaio
U can transform a .XER into a P3 - and vice versa - files using xerp330convert.exe that u can find on Common Files\Primavera Common\Convert
Regards.
salah obaidi
Hi Arthur godbeer...
thank you Arthur for your coorperation..and now I got it.
regards...
salah obaidi
Arthur Godbeer
User offline. Last seen 15 years 6 weeks ago. Offline
You cannot RESTORE from Primavera 5.0 to P3, in the sense of P3’s backup/restore. They are different database architectures, and are not directly compatible. The usual way that data is transferred is using the newer software’s import/export functionality.
