PROJ environment variable is too long
Svein Myklebust
User offline. Last seen 16 years 17 weeks ago. Offline
Get the message:
when running Global Changes.
The network is imported via MPX.
Any experience?
Any ideas?
Svein
Ronald Winter
The bottom line is that your total disk:directory\file name cannot be longer than 64 characters. Look here for an earlier forum on this subject. Good luck!
Svein Myklebust
Thanks for the answer.
The problem was that the path to the project was to long.
Old treads are not easy to find these days.
The search engine is down.
Svein
Raja Izat Raja Ib...
User offline. Last seen 13 years 38 weeks ago. Offline
try to find from the old post thread. The problem is because the file u use is under sub directory to another make it under one sub directory only.
Praves Suppa
User offline. Last seen 7 weeks 3 days ago. Offline
Hello Svein Myklebust,
it might be a causing your project directory whether some of them has more than 8 characters.
Hope can help you more or less.
Praves
