Resource relationship within a task
6 replies [Last post]
Redzuan Samsudin
User offline. Last seen 14 years 37 weeks ago. Offline
Good day to all
It was a relief that I found this forum!!! It is very helpful. Thank you all for your contribution.
My questions is:
Can we link many resources for a single task. Example:
Task = Install & Check Pipe Spool.
Resource use = Rigger, Pipe Fitter, Pipe Welder, Firewatcher, NDT
My guery = Can we link above resources in the task. Rigger SS Pipe Fitter FF Pipe Fitter FS NDT.
Hope you all understand my question.
Thanks & regards.
Redzuan Samsudin
Good day
Thanks for info.
I will check & dload their demo.
Thanks again.
Redzuan
Dayanidhi Dhandapany
User offline. Last seen 4 years 13 weeks ago. Offline
Primavera is task based, so you can’t show linking relationship for resources in P3. you can think of Spider Project Software for that option. you can find a demo copy from their website.
Redzuan Samsudin
Good day
Thanks for the input.
So, the solution you mention is the ONLY way to link resources within a task??
My post/question arises because during my presentation to my boses (yesterday), one of them mentioned that linking resources in an activity is possible --> to achieve a logical Manning Level.
The way he said it, its like linking task by using relationship line.
Is this possible?
Sunley Mathew, PMP
User offline. Last seen 4 years 18 weeks ago. Offline
Groups: GPC Qatar
Hi Redzuan Samsudin ,
In Primavera Project Planner P3 we have an option in the Resource window(used for adding resource to task),for Resource Lag & Resource Duraton.By the proper use & adjustment of these you can for eg. have one resource at the start of a task, another at the end etc.
Rashid Iqbal
User offline. Last seen 18 years 13 weeks ago. Offline
Would not recommend, however, the thing which are looking for can be managed easily if you make resources as activties and then link them as you want. You can certainly make a hammock to umbrella these activities/resources.
Rashid
Vahid Barzegar
User offline. Last seen 16 years 43 weeks ago. Offline
Hi Redzuan Samsudin,
In P3 you can choose a task as "Independent" which based on resources. I think, it is a way to solve your problem.
