batch processing
Vinod Nagarahalli
User offline. Last seen 18 years 18 weeks ago. Offline
Hello,
I want to learn more about batch processing. I use Import/Export to crunch the data, but when it comes to code dictionary it is not possible, though i know that its possible thru batch processing.
Vinod
David Kelly
User offline. Last seen 2 years 28 weeks ago. Offline
Vinod,
You return to the first page of the spreadsheet and chose the "set" button opposite the "get" button you used to read the data
Vinod Nagarahalli
Hi David,
After i change in the excel sheet how do i import back to P3?
Vinod
David Kelly
Vinod,
The spreadsheets in the Samples\Excel directory both read and write data from P3 to excel. There are Access examples as well, BUT they work only with early version of Access.
Vinod Nagarahalli
Hello David,
Thx a lot for the advice. I had one more query poping up which is How do i import back the same back to P3 after working on Ra.
Also there are oyher things like Access,VB,SBL etc, how can i use these stuff.
Thanking u in advance
Vinod
David Kelly
Vinod,
You should use the RA facility to batch import/export the coding structures under the "data" pull down. Copy the Entire RA directory from the Primavera installation CD, and check out the "project.xls" spreadsheet in the "Excel\samples" sub-directory within it.
