levelling of resources
sunil kumar
User offline. Last seen 14 years 47 weeks ago. Offline
once i do levelling of a particular resource... and scheduling it will again come to where i started... how can i retain the schedule as it is( i mean levelled schedule)
Alex Wong
User offline. Last seen 11 years 32 weeks ago. Offline
Groups: TILOS
Echo.......................
Back to the original question
What I normally do is to save a copy of the levelled schedule as a target schedule for later reference.
In addition, the reason that you don’t really need to keep the schedule becasue each time the senario changes you will need to re-level your schedule base on the new conditions. What you however need to save is your levelling setup.
Priority, Float control...
HTH
Alex
Zhang Haixiang
User offline. Last seen 4 years 4 weeks ago. Offline
Sunil,
I agree with Ronald. Creat a custon data item to store leveled date for reference.
and be careful using constraints. After updating your schedule, you’d better re-schedule and re-leveling, because critical path/total float/free float may change, the result of leveling will also change.
Ronald Winter
It is easy to remember scenarios. Create Custom Data Fields for the Early Dates and then use global edit to transfer the leveled dates into this new field. Done! Good luck.
Hemanth Kumar
User offline. Last seen 1 year 18 weeks ago. Offline
Not Possible My Friend
Levelling gives scenarios
if you want to retain dates note it down and constrain activities
