Resource leveling
Achim Kempf
User offline. Last seen 9 years 14 weeks ago. Offline
During Precommissioning one team has to do loop checks in 20 commissioning systems, which are partly related to each other. The systems contain 1 up to 250 loops. The team is able to handle 40 loops a day. How can I manage P3 to calculate the early start of the loopchecking per systemn respec. the sequence of the systems to be checked?
Regards Achim
Philip Jonker
User offline. Last seen 16 years 11 weeks ago. Offline
Hi achim,
Forgotten me
Achim Kempf
Thanks Jaco it worked. Regards from Munich Achim
Jaco Stadler
User offline. Last seen 18 years 18 weeks ago. Offline
Hi Achim
I WOuld Suggest you go to the Following Method.
1) Open a P3 Schedule (in Hours)
2) Create the 20 Systems as Activity
3) Calcultate the activity Durations
Example assume System has 80 loops and you said 40 loops a Day (Assume 8 working hours) This mean activty duration is 16 hrs
Do the system Inter Logic
Assign a Resource "Loops" BQ (Number of loops / Systems)
Press level (Assign the resource Loops) Make Normal & Max lvl 5 (40 loops /8 Hours)
