data tranfer to/from P3 to MS Access
8 replies [Last post]
Gün Göksu
User offline. Last seen 2 weeks 6 days ago. Offline
Hello fellow planners,
Anyone can please send me some examples (macro?) to transfer data from P3 to MS Access and back?
I need to link some data in an Access Database to P3.
(by way of mirroring the P3 data tables in Access)
Gün Göksu :)
Cor de Bakker
User offline. Last seen 14 years 6 weeks ago. Offline
If you want to link P3 data into MS Access you have to install an ODBC driver that works with 16 bit data.
Doing so, ou can use P3 data directly in MS Access.
But you have to know how some things work, Otherwise it will crash instantly.
Steven Oliver
User offline. Last seen 12 years 34 weeks ago. Offline
Why not export to a dbf file, this can be read directly by MsAccess
Kevin Button
User offline. Last seen 3 years 29 weeks ago. Offline
I don’t have a copy of P3 with me so I am guessing here. You need to go to Tools, Updata Data Dictionary and select Advanced. This will make your custom data fields available for RA to use.
Don’t know if this will solve your problem, but I think you would have to do this anyway.
MK TSE
User offline. Last seen 5 years 6 weeks ago. Offline
The file is running on Access verion 97.
Gün Göksu
Hello,
I’ve found the file from the cd.
\P3\Ra\samples\access\PRIMAVER.MDB
there is no documentation with it.
moreover, some stuff dont work in the file.
I did get the activity table. but not the CUSTOMCDI.
it gives an error: 3315 Field ’activityCDI.value’ cannot be zero-length string.
what could be wrong? any clues?
Gün.
MK TSE
There ia a MsAccess file on the CD which can link to P3 by RA also.
It performs same as XLS.
Bill Guthrie
User offline. Last seen 9 years 9 weeks ago. Offline
forgot, also there is a file in many p3 disc for upload, called projects.xls
this will export all your schedule in one pass to a excel file.
cheers bill
Bill Guthrie
use p3 utilities, export 2 files
1 with schedule data
2 with relationships
after you get export in database, merge the two excel files and you have a complete schedule in db and can play with it in access then back to p3
enjoy.
