50% of workforce on non-work days
Katalin Hovanyi
User offline. Last seen 11 years 5 days ago. Offline
From now on we need to start working on non-work days. Can somebody suggest an easy way to allocate 50% workforce for non-work days?
Raja Izat Raja Ib...
User offline. Last seen 14 years 5 weeks ago. Offline
ya...u doing the right way using excel then import..i forgot about excel... U can do automtic caculation using excel formula..then import the file takes a minute to do that...
Katalin Hovanyi
Thank You Ibrahim,
I was afraid that I neet to burn a few night candles to complet this changes or go back to do a lot of things in Excel.
dear katalin,
to make it 50% resource in non working days as u said absolutely cannot be done unless at first setup the file u select planning unit in hrs...the other way, u can define every activities that working in non working days then u have to deduct 50% using global change or manual calculation. Its little bit tedious...to select one by one from the budget cost.
regards
Katalin Hovanyi
Thank You Bill,
Can You be a little bit more detailed. The resource curve based on duration percentage, so how can I hit the non-work days with the half workforce for hundreds of activities with different start date?
Bill Guthrie
User offline. Last seen 9 years 7 weeks ago. Offline
apply 7 day cal. and then apply resoruce curves, set up your curve percentages.
after a test run you might do global.
have fun bill
