Project Group & Targets
John Impraim
User offline. Last seen 12 years 41 weeks ago. Offline
Hi Guys,
I have 2 stand alone projects (with targets) which have been made sub-projects to a new project group. Now, how do I display their Targets at the project group level ?
Any help out there ?
John
Sukumaran Subaram...
User offline. Last seen 9 years 15 weeks ago. Offline
Groups: GPC Malaysia
Make a copy of new project group (eg.PG01) and rename it (eg.PG02). The subproject will be copied together. Set PG01 as a baseline (target) schedule and PG02 as current working file. Go to Tools > Project Utilities > Targets and set PG01 as a target file for PG02.
Regards.
Philip Jonker
User offline. Last seen 15 years 48 weeks ago. Offline
Hi john,
If you have the two target projects, combine them in the same way you did with the updated projects, in a multi project file, and add the same sub-project id’s, and use this group as your new target.
Steven Oliver
User offline. Last seen 11 years 50 weeks ago. Offline
You would have to prefix the activity id’s in your target plan with the same prefix you used to create your sub-projects.
This can be done with a Global Change (Actid = xx&actid), though depending on how your activity id is made up you may need to use the ltrim or left/right text functions.
HTH
