export from P3 into PDF
Luca Meli
User offline. Last seen 19 years 29 weeks ago. Offline
Hello there,
can anyone explain how to export a P3 layout into a PDF file? I have tried to save (as web page) as JPG or PNG and then opened them by acrobat but the result i got is not good as other P3 layout exported into pdf files I have seen. is there another way to do it?
thanks in advance
Luca
Ian Wilkinson
User offline. Last seen 13 years 27 weeks ago. Offline
There is a freeware solution which I have used and it works fine in creating PDFs from P3 (or any Windows application).
It is called Cute PDF Writer, available free from:
http://www.cutepdf.com/Products/CutePDF/Writer.asp.
Here are some instructions which I hope help:
Close P3. Next Install the Cute PDF Writer software.
Next set the Cute PDF Writer as the default printer in Windows (Settings/Printers). Next open P3. Next open your P3 project. Next print your required layout and it will print to PDF format.
Steven Oliver
User offline. Last seen 12 years 1 week ago. Offline
You need a pdf writer. This then appears in your list of printers.
The most popular is Acrobat which you have to pay for, alternatively there are a number of freeware/shareware solutions available.
HTH
Luca Meli
Sorry Guys
I found it in the forum.
It works
thanks
RE: P3 convert to PDF file
Aleli Florencia Marquez,
I’ve had similar problems when printing to PDF.
You need to make PDF the default printer first and then print in the normal way.
Another P3 Idiosyncrasy.
