Error Message Help required
Tony McClennon
When using P3, I have started to receive an error message "PROJ environment variable is too long" when trying to recalculate.
Has any of the PP membership had this problem and if so, what the solution was?
Tony McClennon
Tony McClennon
Steven,
Many thanks - I have moved the file location to another location and all is well with the (p3) world!!
Tony McClennon
Steven Oliver
User offline. Last seen 12 years 32 weeks ago. Offline
Ah !, the old Proj Environment message.
Basically, the path (C:\P3win\etc.....) to your project files must be less than 64 characters.
If your files are embeded deeper into a directory structure than that the "Proj Environment " error occurs.
HTH
