Copying File - Error Message!
P3 Scheduler
User offline. Last seen 20 years 36 weeks ago. Offline
Groups: GPC Malaysia
Numerous occassion when I tried to copy a file (which is not opened, eg. APEX), I received the error message "Cannot open files for project APEX".
However if I open the file and then execute the Copy command, then there is no problem. Any clue why the error message if the file is closed?
Thanks and best regards,
CS Ong
P3 Scheduler
Thank you Planning Planet Team. That was a quick reply!
CS Ong
Forum Guest
User offline. Last seen 36 weeks 4 days ago. Offline
Hi CS,
We have experienced this issue before.
The way in which Primavera advised us to fix it was to re-install the P3 software. It was apparently caused due to some windows programmes being "open" when the P3 software was installed.
Hope this helps.
The Planning Planet Team.
