Need the PRMBATCH Commandline parameters
11 replies [Last post]
Marc Borburgh
User offline. Last seen 11 years 3 weeks ago. Offline
Can anybody help me with the command line parameters for the PRMBATCH.EXE ?
I’ve used them many times in the past and now that I want to automate something again, I can’t find them anymore.
Could anyone please post them here?
Arminder Singh
User offline. Last seen 16 years 29 weeks ago. Offline
I am trying to execute a batch file to get schedule informaton in DBF format using following PRMBATCH command parameters on command prompt.
PRMBATCH REPORTS < input filename > 0 0 /EXTENSION=P3
But whenever i tried to get dbf information of project which is on location other than the default project location. It did not work fine.
Could anyone help me to sort out this problem?
IC Quiamco
User offline. Last seen 13 years 38 weeks ago. Offline
I send e-mail to help desk about this error hope they received it.\
Marc Borburgh
Sorry Moderators,
You can see how I, by accident, found this. I did not have the time to find a email addy from a moderator to report this.
Good to see it’s solved, otherwise I would have taken the time to tell you about it :D
Forum Guest
User offline. Last seen 15 weeks 1 hour ago. Offline
Sorry about that. Is should be fixed.
Regards.
Dayanidhi Dhandapany
User offline. Last seen 3 years 31 weeks ago. Offline
What happened to this site, very strange in displaying of this forum message?.
hmmm........
Marc Borburgh
hmmm, nice error on the forum
Marc Borburgh
Finally found it.
Finally got my hands on the P3 3.1 CD, but nothing about this was on there. Then I spotted the P3 2.0b cd and there it was :D
To, maybe, help others that might be lookign for this later, the commandline parameters for PRMBATCH are:
< PROGLOC directory >PRMBATCH REPORTS < input filename > 0 0 /EXTENSION=P3
Marc Borburgh
I know that, but thanks.
I realy need the COMMAND LINE PARAMETERS.
I need to schedule a job that runs everyday at 7:00am.
I have the batch script all in place, now I just need to know how to call the PRMBATCH.EXE with the correct parameters. There should be parameters for selection of the PROJ location, the BATCH FILE location, P3 or FH, REPORT or GRAPHIC and some more stuff.
Anybody?
IC Quiamco
1. Create a batch file in your project directory, that contains information you want.
2.To run the batch program, choose File, Run from Windows Program Manager and enter the following in the Command Line:
C: P3WIN P3PROGS PRMBATCH.EXE
3. Confirm the batch file directory, C:P3WINPROJECTS, and enter the batch file name, then click Run.
Here are two PRMBATCH Commandline parameters which I often used when I create a acvity codes dictionary.
-CDEF is the record required to define the type of code field (activity code or activity ID), the location of the field in the activity ID or code string, and the name and description of the field. Each CDEF record defines a single code field.
-COTL is the record used to define title code values.
Marc Borburgh
Yes, there should be a file called Batch.wri on the CD. Unfortunately I have no access to the CD, nor to the knowledgebase of P3. :(
Steven Oliver
User offline. Last seen 11 years 50 weeks ago. Offline
Wasnt there a manual included on the CD ?.
Its so long since I used Batch that I wouldnt even know were to begin.
