P3E in Powerpoint
Forum Guest
User offline. Last seen 30 weeks 23 hours ago. Offline
I’m sure that most of you, or at least most of your bosses, at some time or another must have to present a schedule in meetings. In order to do this I have been trying to get something reasonable out of P3E/c that can be put into powerpoint and subsequently shown on a slideshow on a projector. Does anybody have a good way of doing this? So far I have tried PDF’s, but it seems difficult to get a clear image without a sort of blurring effect.
Bernard Ertl
User offline. Last seen 10 years 10 weeks ago. Offline
Hi folks, please start new topics related to P3e & P3e/c in the appropriate forum. This forum is for P3. Thank you for your cooperation.
Bernard Ertl
InterPlan Systems - eTaskMaker Project Planning Software
Forum Guest
We’ve had the same problem with P3 getting reasonable graphics to insert into powerpoint.
PDF’s with a high dpi, then extracting images work, but are a lot of work and the quality is questionable. Metafile just don’t work well enough, and they are never precisely the same as the normal print-out (they are bill-gated?).
We finally found an application that works VERY well, Peernet E-Pro. Their site is www.peernet.com, and they have a freebie demo available, the cost is pretty reasonable, about 130 for 5 copies.
This software "emulates" a color printer but converts the output to one of many graphic formats.
I like to use 8-bit color .png format at 300 dpi. This gives me a great overhead projection quality. But you can go to 24 bit 1400 dpi if you want. We also use this a lot for those Excel tables that get cut off when you cut and paste to Powerpoint.
The only problem....a lot of resources are used, so with a big multipage output you need to get up and take a coffee break. One more tip, get the Powerpoint "Photo Album" plug in from Microsoft, it automatically inserts any number of graphics and resizes them to fit. Saves a ton of time.
Zq qz
User offline. Last seen 13 years 5 weeks ago. Offline
You can save it AS METAFILE : GO TO THE FF MENU:
FILE >>> PREVIEW PICTURE >>>SAVE IN METAFILE .. THEN DO COPY PASTE ETC........
hOPE IT WORKS
