Oracle Projects vs Primavera
Mohamed Gebriel
User offline. Last seen 11 years 14 weeks ago. Offline
Hello Planners,
Has anyone out there worked on Oracle projects in planning and control?
I would appreciate if someone could give me limitations or advantages it gives in real application versus Primaveras P3 or P3e.
Mokhtar brahim
User offline. Last seen 22 years 20 weeks ago. Offline
salem alaykoum
je cherche le logiciel Primavera P3 , et si c possible des documentations sur ce logiciel.
si tu veus d autre renseignement voilĂ  mon e mail
mokhtar_brahim@hotmail.com.
merci
Mokhtar.
Mohamed Gebriel
Ali,
Thanks for the information, but what I was really pointing to was "Oracle Projects", which is a complete module provided by Oracle for project management and works alone.
In P3e, Oracle is just a hosting DB environment. so I dont if anyone can provide his comments on his application of "Oracle Projects".
Ali Vessali
User offline. Last seen 7 years 46 weeks ago. Offline
Mohamed Gebriel,
As far as I know, the Primavera Project Planner (P3) uses the Btrieve Database engine but Primavera Enterprise (P3e) uses the Oracle Database engine.
As you know the Oracle Database designed for large volume of data processing with high security and high speed processing. So when you want to have multi huge project schedule with full resource assignment and cost loading, concurrent multi user updating and other specific data processing, you should have a strong database engine such as Oracle.
Ali Vessali
