Back up file
Abraham Banlawe
User offline. Last seen 13 years 28 weeks ago. Offline
Im running P3 ver 2b.. I had to copy my file to a recordable cd as one of the back up but whenever I browse the recordable cd it cant read from there any suggestion ...
A.Jaffer Sadiq
User offline. Last seen 7 weeks 10 hours ago. Offline
Groups: GPC Qatar
u can copy to desktop it will open
Ali Hamouda
User offline. Last seen 8 years 39 weeks ago. Offline
Yes sir,
you are right,I have met this problem,and to overcome this.I copy the files to my Hard disk then I go to properties and I change the file attribute to archeive instead of Read only.
But I don,t know whether there is a choice in the burning CD, to copy and change the file attribute to archeive(I.e not read only)?
thanks
Robin Jongen
User offline. Last seen 17 years 3 weeks ago. Offline
Back up to a CD. When you burn something on a CD the software makes everthing read only. This is why you can not run it from a Cd. Regards, Robin Jongen
Greg Stacey
User offline. Last seen 7 years 2 weeks ago. Offline
P3 will not read files from a CD. Use the P3 back-up function to minimise file size when backing up, then restore from the CD to your computer/server.
Mohd Mahd
User offline. Last seen 17 years 4 weeks ago. Offline
well, try to copy those files to ur hard drive. then change them to a readable status. then, they should be workable one if they were not damaged.
If u will not be able to copy them, it means u have a bad cd copy, ... not usable.
wishing it was of some help. Mohd
