Producing Reports from P6
Robert Corran
User offline. Last seen 2 years 8 weeks ago. Offline
  Good Morning All I am using P6 v16.2 I cannot get a report out of it formatted as I want it to be, it is a simple report showing planned units for labour and materials, when I export to excelas an xls file the data on each line is one long line of text, why? In all previous P6 applications I have used it has come in as a tabluar report withthe data in the correct columns etc The way I have got round it at the moment is to take off the file extension, then dump it into wordpad, then import the text back into excel, seems a pointless long winded way of doing things,is there something Iam missing here, a setting somewhere for example? Any Help would be appreciated
User offline. Last seen 33 weeks 3 hours ago. Offline
You can simply copy all the data from the activity (or resource assignments) view and paste into Excel. Or Alternatively, setup a layout with your required columns, grouping, filtering etc, then select TOOLS>REPORT WIZARD and select the "Use Current Screen" option.
Joel Roberts
User offline. Last seen 27 weeks 4 days ago. Offline
Hello Robert,
You might also want to consider trying out the reports in the pro version of ScheduleReader. It is a handy companion tool to your P6 and could potentialy simplify your reports creation process.
User offline. Last seen 9 weeks 3 days ago. Offline
just do it in the data area as columns then highlight everything and copy and pate to excel
