Error in P6 R8.2- Application Event
S
san TS 👤 Member for 14 years 5 months
Hello,
Iam doing a Time impact analysis and in the Projects layout , i was copying and pasting the baseline to create more windows for analysis. After doing this and completing few windows, there was an error as shown below,
"An application event has been intercepted. Please note the event code for reference.
Event Code  PPUSP-0516-B".
I understand that this is due to size constraints. Then i tried to delete some projects, but then again there is another error(another application event code  UPDAT-1921-B).
Please let me know how to fix this.
San TS
Z
Zoltan Palffy 👤 Member for 16 years 10 months
Go to Start
All Programs
Microsoft SQL Server 2005
SQL Server Management Express Studio
S
Thanks Zoltan.
I tried deleting the activities but it still doesn't work.
There is no issue in exporting the files.I have saved all in xer format. The problem is in importing.
Regarding the Microsoft SQL server 2005, i could not find SQL Server Management Express Studio folder. Is that the dll file?
San
Z
just like any windows program you need file space even to delete stuff
first delete a few activities at at time then gradually delte more activities at the same time keep doing this then at some point deleted the entire project.
You can do several things
#1 delete the POBS table that are not needed
Go to Start
All Programs
Server name: is name of computer
Authentication: SQL Server Authentication
Login: sa
Password: Prima123Vera
Click Connect
Click on Databases and expand it
Highlight pmdb$primavera
Up top select New Query
On the right hand side type delete pobs;
Then right click and select execute
Close SQL
Always check for unecessary POBS tables prior to importing and xer file here is the link to the free software
http://scheduleanalyzer.com/PurgePOBS.exe
#2 create another database
You might want to create a second database and start working in that environment if want to have to leave your existing data intact. Another option is to export some of the project files to an xer. You can put more than one project into an xer export by opening multiple projects and exporting them. Then delete the projects.
#3 email project to yourself
Another option is to open the project and select send project and email the xer to yourself. Be careful her because sometimes companies only keep email for a certain time period then they are no longer accessible. You could always move the email to an archived email folder which should not get cleared out.
#4 export to external drive
Another option is to export the xer files to a thumb drive, an external hard drive or a network drive
 #5 Shirink the database
Go to Start
All Programs
Login: sa
Click Connect
rght click select Tasks
then Shrink
Then Database
#6  shrink the files
Go to Start
All Programs
Login: sa
Click Connect
then Shrink
Then Files
exit
