Ordinal date
9 replies [Last post]
UFUK KATIRCI
User offline. Last seen 9 years 26 weeks ago. Offline
Hello everybody,
I am searching an answer for showing ordinal dates instead of ceartain dates but I couldn' t find a specific way. My problem is the project start date is not certain and I want to show the dates as ordinal dates, like to day 1, 2 etc instead of 25 dec, etc.
At columns part I want to show ordinal date instead of BL project start - end.
I will appreciate if someone can help me,
Thanks & regards,
Ufuk
Jerome Odeh
User offline. Last seen 4 days 20 hours ago. Offline
Ufuk,
Follow the steps below.
  • Create 3 UDFs as shown in screenshot below
    3208
  • Create a Global Change using the the 3 UDFs created above. Remember to replace 19-Jul-99 with your project start date and apply the Global Change
    3209
  • Add 2 columns to your schedule for Start Day & Finish Day using the UDFs user_integer_1 & user_integer_2
    3211
  • Voila, your ordinal dates should now be visible on your schedule
    3212
=jerome
UFUK KATIRCI
These data do not appear at my primavera (P6 R8.3.2), still couldn' t find a way for this ...
UFUK KATIRCI
Jerome Odeh
Under Global Change, you should find these fields under the "Then" section parameter. See attached screenshots.
3206
3207
UFUK KATIRCI
I have tried, I checked my primavera but couldn' t see any "user_start_date1" or "user_integer1" etc. How can we create these.
Thank you,
Jerome Odeh
UFUK KATIRCI
Amro thanks for your answer, there was ordinal dates column available at previous versions but it is not available at the latest version, I guess.  I can hide the dates columns but I have to show ordinal days ...
UFUK KATIRCI
Amro Ahmed
User offline. Last seen 3 years 33 weeks ago. Offline
my suggestion to you to show in Gantt chart and just hide  colums of dates on activity table .
Because in User Preference this not available option.
