Webcast Invite - Cost Loading into Primavera P6 (Tuesday 14th July 2015)
Greig Duncan
User offline. Last seen 9 years 51 weeks ago. Offline
Primavera P6 Integration with Legare
Cost Loading your P6 Schedule - An Improved Solution
In partnership with Forgetrack
10.30am - 11.00am  BST
Click here to register
We would be delighted if you could join us for a 30 minute live webinar, introducing Legare and the tool's effective solution to cost load (bucket load) a Primavera P6 project.  Loading profiled cost data into Primavera P6 is a time-consuming and expensive process - which typically involves typing in the values in cell-by-cell.  Typically known as "bucket loading", this task is frequently open to error and can be a considerable drain on planners' time.
Legare has the capability to transfer key project data from Excel direct into Primavera P6.  The cost loader is a simple to use and very effective application gives you the ability to load cost data into your Primavera P6 schedules.
Here's what else Legare can do:
·  Loads data from any source, e.g. SAP, Oracle, Maximo, Microsoft Project, JD Edwards and contractor Work Management systems
·  Loads activity codes, costs, expenses, resources, and roles.
·  Data Connectors include XER, CSV, Oracle, Excel, XML, P6, Access, and MS SQL
·  Uses the Primavera P6 API
·  Scheduling, Forecasting, Dictionary Synchronization and Relationships
·  Optional modules: Project Loading, Microsoft Project Import/Export.
Webcast Agenda - A live demonstration of Legare 'Cost Loader':
·  Technical Overview: Legare architecture and features.
·  Demonstration : Uploading bucket loaded cost/unit from spreadsheets direct into Primavera P6
·  Question & Answer Session
Thank you in advance for your interest - if you have any suggestions or feedback, please contact me. Further information and connector types can be found at www.collabro-legare.com
Best Regards.
Greig
Greig Duncan
Legare Global Channel Manager
