Successors calapse when manually starting or completing a predecessor
Charlie Daniels
User offline. Last seen 10 years 26 weeks ago. Offline
When I manually tick the start option of a task and then hit shedule, the successors will fall back to the data line.
The same thing happens when I Manually complete a task the successors will fall back to the dataline.
Is there anyone with a solution to this problem?
P.S. Manually complete or start meaning not with the datadate update.
Sendhil Kumar
User offline. Last seen 9 years 48 weeks ago. Offline
Hit F9 --> Options --> "General" tab --> check retain logic option.
Charlie Daniels
HI Anas
"You are probably suing progress override option in the advinced schedule options menu. Change this option to retained logic and successors will not fall back on the data date."
Where do I find this option, I am using P6.7?
Anas Nasr
User offline. Last seen 8 years 24 weeks ago. Offline
User offline. Last seen 9 weeks 6 days ago. Offline
Gary Whitehead
User offline. Last seen 5 years 47 weeks ago. Offline
Are the actual start/end dates you are manually entering earlier or later than the data date?
When you say "fall back" to the data line, do you mean the successors become later than they were showing before you scheduled, or earlier?
