Several Crews in Vico Control 2009
Hi all,
I'm using Vico Control 2009 demo mode and I would like to know if it is possible to put multiple crews in a particular activity.
Grateful.
F
Forest Peterson 👤 Member for 15 years 3 months
Conditonal Yes,
On the edit task/resources tab the crew composition is composed by you - so define it with two crews; after the crew is added then change the supplier from the supplier defined on the general tab to the 2nd crews supplier.
J
José Otávio 👤 Member for 14 years 9 months
Hi Mike
No, by this way the program reduces the duration in each locations. I`ve learned another way: Spliting the task so you choice the locations for each "crew".
Best regards.
José Otávio
M
Hi Jose
I have limited knowledge of Vico but I do recall that you can apply any number of crews to any one task line.
As I recall if you have resourced the task correctly then by moving the end of the distance line horizontally across the time line the number of crews adjust automatically.
Featured Partner
Robert Guers
Jerry Robinson
Elyar Safarov
Christopher Ganotice
Ola Gbotoso
pennyu
jaasland
Doron El
Erim INANC
Our Partners
