Man power Productivity
13 replies [Last post]
Arun Vasanth
User offline. Last seen 6 years 18 weeks ago. Offline
Groups: GPC Qatar
Dear Friends
It will be highly appreciated if you will be clearing my doubt ASAP.
Eg .I have a task of block work of Quantity  400 M2 .
Kindly clarify the production in the attached picture .
2.5 M2 per Hour means it is the production rate of one mason ???/Thn what is the propotion of helper .Kindly  give me the global propotion of Labour with the masons (block,plaster,shuttering,Steel fixing what ever).And also Please compute me the Block mason with the helper for the above quantity....
Arun
643
Gary Whitehead
Dear All:
If anyone wants the productivity info from Arun, please send him a private message with your email ID (click on the little envelope next to his name).
I'm locking this thread before it becomes full of begging letters.
Dura Cell
User offline. Last seen 3 years 51 weeks ago. Offline
Dear Mr.Arun,
Please send me a copy as well my email is d.cell@yahoo.com
Thanks in advance
Dura
Dura Cell
Dear Mr.Arun,
Thanks in advance
Dura
shaik yakub
User offline. Last seen 9 years 18 weeks ago. Offline
HI Arun
Can u plz send me a copy to yakub_sky@yahoo.co.in or yakub.sky@gmail.com
Thanks in advance,
Shaik
shaik yakub
Hi can u plz send me a copy on yakub_sky@yahoo.co.in or yakub.sky@gmail.com
thanks in advance
Shaik
Justin James
User offline. Last seen 6 years 19 weeks ago. Offline
Groups: GPC Qatar, TILOS
Hello Mr.Arun,
Can i have a copy as well my mail is sjustinjames@gmail.com
Thanks & Regards
Justin
Edison
User offline. Last seen 13 years 43 weeks ago. Offline
Dear Mr. Arun,
Please send me the productivity rates at use private message service
Owais
User offline. Last seen 20 weeks 1 day ago. Offline
http://www.escsi.org/uploadedFiles/Technical_Docs/SmartWall_Masonry/3700...
Without drawings and specifications you cannot make a good estimate, it is not the same for different block size, not the same production rate for blocks to be installed on the ground than for blocks to be installed using scaffolding. Also the vertical and horizontal reinforcement matter. That is why most companies do not outsource scheduling unless the specifications call for a scheduling software they do not know. It is a pity industry have not realized that scheduling should be done in-house, by the team that will be in charge of the means and methods. We have some specifications that even require the contractor to hire an external scheduler to use their particular software choice, unbelievable but true.
Arun Vasanth
Groups: GPC Qatar
Dear Friends
I got the Productivity rate from a Engineer who  is silent the Forum (Mr.Pinan).
Iam very thankful to Mr.Pinan.
If any body wants  the productivity with Crew Please post their email ID...
This productivity we can use for  GCC Only....
Arun
Arun Vasanth
Groups: GPC Qatar
Dear Friends
Iam Supporting Nidan...
We planners have to prepare a production rate based on the manpower using..
for eg 1000 m2 block work
10 Block builders its propotion of helpers..
If any body have please share...
Arun
Nanding D.
User offline. Last seen 13 years 42 weeks ago. Offline
Hi Planners, Production rate in Planning Planet is great, but I think it will be more meaningful if the Production Rate will be associated with basic Crew Description and Equipment Detail. Thanks, Nanding
User offline. Last seen 32 weeks 6 hours ago. Offline
Hi Arun
The most precise way to get production rates for your project is to look at the tender breakdown.
The individual rates should be set at Labour - Plant - Material.
The money can be converted to hours using the labour rate per hour.
If there is no individual labour rate then apply a reasonable labour percentage - 35% to 40% for blockwork
You should also take account of the other items related to blockwork productivity:
Openings and lintels
Angle head restraints
M&E Openings
Fire Proofing etc.
These should all be added to the blockwork hours and then allocated pro rata to your programme tasks.
m2/mr means some production rate per hour for a crew that can be a mason plus a helper
m2/m-hr would be production rate per man-hour
Production rates without crew description are misleading, even per man-hour, you might have several production rates depending on the crew composition. It is not the same moving dirt with a 10-cm truck than with a 20-cm truck for one hour or one man-hour. It is not the same placing concrete with a wheelbarrow than with a 90-cm per hour concrete pump that can swallow several concrete trucks in an hour with ease, two chutes side by side so there is no waiting between trucks.
