Middle Eastern Project Calendars - Ramadan
Simon Willson
User offline. Last seen 3 years 27 weeks ago. Offline
I am setting up a P6 database in Dubai and am trying to forecast when Ramadan and other religious / public holidays will fall for the next 10 years.  I have a 5 year look ahead but can not source any further than this on the web.  I appreciate that the period of Ramadan is tentative and will depend upon the lunar cycle for each Middle Eastern region.
Does anyone have a long term calendar resource I could refer to?
Would it be an idea to have a section for calendars in the construction rates / norms?  Just a thought.
Thanks in advance.
Simon
User offline. Last seen 11 weeks 1 day ago. Offline
Move backward 11 days every year.
Rizwan Rauf, PMP
User offline. Last seen 9 years 22 weeks ago. Offline
Hi Simon,
I have conversion calender tool to convert from english to islamic months. you can easily calculate time from that. If needed, let me know.
Rizwan Rauf
User offline. Last seen 10 weeks 6 days ago. Offline
Hi Simon
An alternative is to do the same as my project in Kuwait - Employ Coptic Egyptians.
Simon Willson
Thanks Daniel,
I have a 5 year look ahead so have been able to update my project calendars to this point.
My project for the last period of Ramadan was working in the desert in Iraq.  Construction workers tended to commence work at 04:00 and were finishing work around 12 each day however, I noted that production rates were not as competetive as usual.  I set up my calendar to forecast probable output and reduced effectiveness by 50% to account for the loss in production.
Simon
Daniel Limson
User offline. Last seen 5 years 29 weeks ago. Offline
Hi Simon,
I think base on my observation Ramadan moves (minus) 1 month every year until it completes a full year cycle..so fo example, if Ramadan this year falls on the month of say July, next year would be June, the following year would be May.
You need to verify it though. However for forecasting purposes you can always consider 1 month per year.
Daniel
