MEP Clearance delay : Tower Project : Interior Sub Contractor
Hemanth Kumar
User offline. Last seen 1 year 28 weeks ago. Offline
MEP Clearance Delay  : Tower Project : Interior Subcontractor
during tender stage a sigle date MEP clearance was given for an entire floor ( A floor is having 30 Rooms \Areas)
Interior Sub Contratcor Submitted a plan based on floor clarance dates taking a certain amount of duration to finish a floor , say 100 days
Actually at site only a small  part /  clearance was given on the planned MEP clearance date
and after 100 days still several rooms in a floor not cleared for subcontractor
How effectievely this delay can be demonstarted in updated plan were there is no roomwise plan submitted ?
Hemant
Hemanth Kumar
Thanks for all
I am planning to proceed like this
 I think the duration we have taken in the baseline is  considering a complete clearance at once
if the area is not 100 % cleared , i will have to revise the Original duration based on % age of area cleared
either weighted area or floor are %
regards
Hemant
CHARINA MATIAS
User offline. Last seen 10 years 43 weeks ago. Offline
I would suggest that you list down all the remaining rooms to be cleared. Make an adjustment in your updated plan for the clearances of each room. Take note that the adjustment can cause an additional variation order in the future.
Magdy Mic
User offline. Last seen 11 years 51 weeks ago. Offline
Hii  Hemanth,
I have the same case of that, And the you should send a notice of delay for the MEP contractor or the main contractor, Demonstrate the impact of that delay showing the variance in dates for clearance , Then later on you can send Interim claim taking every delay case individually.
Best Regards
MAGDY
michael ramos
User offline. Last seen 7 years 44 weeks ago. Offline
Hi i think it will be difficult to defend if not room wise
you will need to submit an excel file with room/area wise clearances
