MSP 2007 Conversion to Primavera P7
Vineet Shrivastava
User offline. Last seen 13 years 45 weeks ago. Offline
Dear Members
I need urgent advice on conversion procedures for conversion of my programme in MSP 2007 to Primavera P7.
I have tried many ways but failed to do successfull conversion.
Please advice what is the correct procedures to convert MSP 2007 to P7
kamesh avasarala
User offline. Last seen 5 years 3 weeks ago. Offline
Dear vineeth ,
the procedure is 1st you go to ms project and save as  that ms- project in XML format . and that can be easily import in primavera when you impotr you select import and selet msproject xml import option and do import . iam doing the same thing i easily doint that in same method.
Kamesh
Alain Wagner
User offline. Last seen 7 years 45 weeks ago. Offline
You are right.. you have to delete summary activities as welll as changing the activity type that will be iported as Ressource type instead of activity type. calendars will have to be converted to your calendar since the MS calendar will be the one imported in your P6 database.
Daniel Limson
User offline. Last seen 5 years 49 weeks ago. Offline
Hi Vineet,
Try importing it, it is not an exact conversion, but you can always delete the summary bars that you do not need.
