How to forecast construction manpower ?
Jinsong Luo
User offline. Last seen 5 years 23 weeks ago. Offline
Does anyone know how to forecast the direct manpower at the very beginning of detail design?
Under following circumstance;
1. Basic Design completed.
2. Detail design not completed, we have no accurate MTOs.
3. Chemical plant
I just know there are about 300 pcs equipments, 14 areas or units, including 1 MCC room, 1 cooling tower, 1 production building with 9 floors and 50 meters high, 1 piperack about 200 meters long, others are tank farms(about 15 site prefabrication tanks) and accessory buildings .
Can any one give me some idears?
Samer Zawaydeh
Dear Larry,
It seems that most of the structures that you are listing are steel structures. Usually this is Fabricated and Painted or galvanized by a steel fabricator and then shipped to site for installation.
If you are trying to estimate the Fabrication time of the Fabricator, then this depends on the selected Fabricator and their capability and empty capacity and the type of steel that you are Fabricating. If you select a large Fabricator, then they might be able to give you up to 1000MT and more per month. The range is very wide for smaller fabricators.
For erection time, it depends on the method of construction. For standard buildings, the main structure is quick, cladding takes more time.
The more specific your questions is, the better we can answer.
Samer
Omar Grant
User offline. Last seen 16 years 5 weeks ago. Offline
Hi Larry - is there any kind of cost estimate you can get manhours/quantities from? Otherwise you may have to look at equipment/structural/civil drawings etc and take an educated guess!! As long as you record the assumptions upon which your estimate is based eg if you use, say, 20 manhours per ton of structural steel. Also if you have access to similar project’s records you may be able to pro-rata direct hours according to scale difference in the plants.
cheers,
Omar
