Dry wall partition changed to CHB plastered Finish
S
Samer Zawaydeh 👤 Member for 17 years 10 months
Dear Christian,
Do not underestimate your client. After all they managed to own a 39 story building.
One of the best ways is for you to take him to site and let him witness the duration of activities and the difficulties of both systems. I am sure that you can find different sites using both system under the same Contractor.
Good luck,
Samer
C
Christian Niedo 👤 Member for 18 years 1 month
Thanks for the insight sir. Do you have a suggestion on how to present this on a "layman’s" point of view for the owner to understand. We are about to start the partition walls by the way.
Christian
N
Neeraj Agarkar 👤 Member for 22 years 11 months
This depends upon where you are right now in the program. If you are able to establish that dry wall used to take up less time per floor whereas wet works take more time (for example, MEP services would get delayed with wet works and more so for followon cvil works..), then you have a case. I suggest you draw up an alternate program for finishes work with palstered finish and account for all the delay that you have to encounter for say, tiling, MEP services, ceiling works etc.
Generally dry wall take lesser time so you have a case for extension. Also, your methodology will change (plastered finish does mean lot of lead and lift for materials and affect tower crane or hoist usage.. if these are covered under some other item in BOQ, you may claim cost overrun on that head, even if the lumpsum rates are fixed for wet works.
regards
C
Mr Iimos,
Actually the owner can really save some cost since we are on a lumpsum contract and as per bill of quantities unit rate for CHB and plastering etc. is lower than the agreed rate for dry wall... but in actual situation in terms of hauling of materials, inst’n of embedments, repairs, debris disposal and laborious works.. makes it complicated. But then again BOQ rate shall govern on the said changes...
You mentioned the Client and the Architect made the decision, without consulting the Structural Engineer? I believe 4" CHB + plaster is heavier than the dry wall (ficem board).
Saving Costs? you can only prove it thru quantities, cost of materials, and the time and other resources involved to execute the works (you can make a comparative analysis).
The Client’s Rep. maybe right for saying that CHB can start sooner, but it’s up to you to present a reasonable and justifiable analysis.
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
