Summarization for Custom data item-Please help
Florante Ileto
User offline. Last seen 13 years 50 weeks ago. Offline
I am preparing a schedule with 3 calendar id
1-No Friday & Saturday
2-No Thursday, Friday & Saturday
3-7 days work week
Each of these calendars are being used alternately per activity
My problem is, I need to show the total durations base on calendar 3.
I made a custom data item, titled it DUR.
I used GLOBAL CHANGE to create formula as follows:
If Cal = 1, or Cal=2, or Cal=3
Then DUR=EF-ES
I got the result I want
What lacking in this is, it is adding up the total duration per activity.Instead of 240 days, the total is 768 days.
I look at tools=>option>summarizing but none
I also look at autocost but nothing I found.
Anybody?
Thanks & Regards in advance.
RANTE
Doha, Qatar
Glenn Douglas
User offline. Last seen 2 years 50 weeks ago. Offline
Rante,
If you are using P6 (with ’Undo’) and you only you need a quick ’what if’ scenario, you could add the ’calendar’ column (From ’General’) change the first acivity to 7 day workweek then use ’fill down’ see what your finish date is compares to the original calendar.
Then ’Undo’.
If your using P5 then make a copy which can be deleted afterwards.
Dieter Wambach
User offline. Last seen 8 years 10 weeks ago. Offline
Rante
Sorry I currently have no solution; just tried with a UDF.
EF-ES uses the same calendar as the activity. My idea was that it may use the base calendar.
Florante Ileto
Thank you Dieter for your reply, but what I need is to show durations(Total Durations actually)of the whole project.
You see, P3 have a standard "Orig Dur" Column, wherein the formula that it uses is generally EF-ES.
Since I am using 3 different calendar id,it does not reflect the total calendar days but working days only on the Summary.
What I need is another column which works same as that of "Orig Dur" column but uses calendar 3 only without changing anything from the logic of the schedule.
Thank you again.
RANTE
Doha, Qatar
Dieter Wambach
Rante
I assume you want to show durations of some groups of activities. May be you’ll use a Level of Effort or Hammock for each group and assign cal no.3 to them. In your presentation or report you’ll show only these LoE - by a filter.
