EARLY AND LATE SCHEDULE
forat faris
User offline. Last seen 9 years 28 weeks ago. Offline
HI ALL
CAN ANY ONE TELL ME IF I CAN USE REPORT(EARLY AND LATE SCHEDULE) TO GET PROGRESS%(BASED ON MD)?
USUALY ..I USED REPORT WRITER TO GET (MD)BY USING (BQWP)..
BUT WHEN I USE (EARLY AND LATE SCHEDULE) I GET ANOTHER VALUE.... THANKS
Larry Bjorn
User offline. Last seen 12 years 16 weeks ago. Offline
Dayanidhi,
Your statement “if you are in between early and late dates curve, you are safe” is misguiding. S-curves show the general progress of a project. Just because the general situation is within the norms, does not necessary mean that the critical path is under control. Using late dates to evaluate adequate progress sounds like playing with fire to me.
forat faris
THANK U ......
Dayanidhi Dhandapany
User offline. Last seen 3 years 46 weeks ago. Offline
you can use early & late dates to prepare (s-curve), then enter the actual to see where you are, if you are in between early and late dates curve, you are safe. if your actual curve goes below the late dates curve, then you need to take some measures to bring back your project on track.
