Licensed named users
Shahzad Alam
User offline. Last seen 16 years 1 day ago. Offline
Hi all,
When I installed the setup of Primavera 6.0. After completion of installation I received the message
"Licensed named users is less than configured Named
users. Please use the User’s dialog under the Admin menu in Project Management to correct
the problem. Please see readme.txt for more information."
So I did as per message. Now i keep only one user admin & deleted the all others. Furthermore I checked in Concurrent user for Project mangement, all others are checked out.
Still now I cann’t see all level of sample Plan. Some areas only Level-2, other ares Level-4 or activities without area & phase etc. Can any body help me in this regard
Thanks & Regards,
Shahzad
Pradeep Kumar Mah...
User offline. Last seen 5 years 16 weeks ago. Offline
Please go to admin and check to the concurrenbt user.
You will not get the message you are getting.
Try and inform.
PK
