Why 6?
Hemant Shewnarain
User offline. Last seen 18 years 33 weeks ago. Offline
just started to learn about Project Managment and reading about PERT/CPM.
why do u divide by 6? and why do u multiply by 4?
Expected Time:
t = (a + 4m + b)/6
pmkb .
User offline. Last seen 13 years 25 weeks ago. Offline
It’s a weighted average. The 4 and 6 are related to each other in that you have 4 parts of one element and 1 part each of two other elements for 6 total parts. The equation could just as easily have 6/8 instead of 4/6 if the probable estimate was deemed to have a higher weight.
I do not know why 4/6 is generally used as opposed to 6/8, 10/12 or any other weighting factor.
Stacy
Project Management Knowledge Base
Clive Randall
User offline. Last seen 16 years 49 weeks ago. Offline
Charlie
Welcomne back
Bell shaped graph
Standard deviation
Not sure higher maths is required
Standard deviation is very simple ask any site engineer who has worked out the results for concrete cube testing.
But why 6 I thought 32 was the answer
Clive
Charleston-Joseph...
User offline. Last seen 3 years 17 weeks ago. Offline
Hello,
This is related to the theory of probability.
The graph generated is a bell shape.
The equation is similar to mean average.
I hope you understand and recall your mathematics or higher algebra, differential calculus, intergral calculus, engineering mathtmatics or any subject related to mathematics.
Charlie
Steven Oliver
User offline. Last seen 12 years 1 week ago. Offline
Where
a = pessimistic duration
4m = 4 * probable duration
b = optimistic duration
generally accepted "rule of thumb". You could equally propose your own method.
(((a+b)/2)+m)/2) for instance
