THE APPLICATION AND DATABASE VERSIONS DO NOT MATCH - SQLITE DATABASE FAILED TO UPGRADE
VIKAS KULKARNI
User offline. Last seen 1 year 47 weeks ago. Offline
Dear Sir,
I have a PPMDB Sqlite database created in Primavera P6 Version 16 which I want to open in Primavera Version 17 (Standalone).
But I get the following error :
1. THE APPLICATION AND DATABASE VERSIONS DO NOT MATCH & then
2. SQLITE DATABASE FAILED TO UPGRADE
Image Files Attached (3 Image Files)
Thanks  & Regards,
Mr. Vikas Kulkarni.
8432
8433
8434
VIKAS KULKARNI
Dear Mr. Rodel Marasigan,
As suggested by you - "Running / Opening P6 as an Administrator" solved the issue - THE SQLITE DATABASE WAS UPGRADED PERFECTLY"
With Thanks & Best Regards,
Mr. Vikas Kulkarni.
User offline. Last seen 24 weeks 4 days ago. Offline
When you run P6, instead of double-clicking the icon, right-click and select 'Run as Administrator.' This will give you full access to your database.
VIKAS KULKARNI
NOTE : THERE WAS AN ERROR DURING THE SAVING / SENDING OF MY REPLY - THE REPLY PAGE WAS NOT SAVING AND ASKING ME TO RELOAD THE PAGE - I RELOADED THE PAGE 3 TIMES WITH THE EXPECTATION THAT FINALLY IT WILL SAVE MY REPLY - TILL THE END THE PAGE DID NOT SAVE - BUT WHEN I OPENED THIS PAGE FROM THE LINK WHICH HAS BEEN SENT TO MY E-MAIL , IT SHOWS THAT MY REPLY HAS BEEN POSTED 3 TIMES.
VIKAS KULKARNI
VIKAS KULKARNI
VIKAS KULKARNI
Thanks for your reply. I tried your suggestion i.e. I changed both the file name and its location too and then in "Database Configuration" I selected "Add a connection to an existing standalone database" with the new path and new file name selected. The Connection is successful (as before), but during login and subsequent opening it gives the same error (as before - Specified and illustrated in my question above).
With Thanks & Best Regard,
Vikas Kulkarni.
VIKAS KULKARNI
Vikas Kulkarni.
VIKAS KULKARNI
Vikas Kulkarni.
Attempt to copy the SQLite database and rename it with another SQLite database name. Afterward, try opening the copied SQLite database, and it should upgrade to the later version. Sometimes, the cache may still reside on your system, preventing the database from being released.
