P6 Professional R19.12 Importing a WBS from Excel
Steven Montgomery
User offline. Last seen 6 weeks 4 days ago. Offline
Hello,
I would like to import a WBS from MS Excel to P6 Professional. I attempted to do this by first exporting a P6 schedule to MS Excel so make sure I have the correct format. Unfortunately, P6 Professional does not import Excel data that has a column heading including an (*). This means P6 will not import WBS Path, WBS Name, and WBS Category. Also, for some reason I was unsuccessful importing the WBS Code as well.
What is the most efficient way to import a WBS from MS Excel to P6 Professional? My WBS is over 400 lines. I would also be nice to include the Summary Scope of Work with the WBS.
Am I better off manually inputing the WBS directly into P6 Professional?
Any input?
--Steve
Mohammed Ali
User offline. Last seen 2 years 46 weeks ago. Offline
  • See this amazing tool to design and export the WBS from Excel to Primavera.
  • You can prepare thousands of WBS Elements in few minutes.
  • It runs on all Excel versions 32 bit and export to any version of Primavera.
  • Learn about it from these group of Videos, if you would like to get it leave your Email.
https://www.youtube.com/playlist?list=PLFPaRgp0OMtk3Fl88xFKiQjpBD4CnLm0U
User offline. Last seen 15 weeks 2 days ago. Offline
Hi Steven,
You cannot use P6 import/export function in excel to create a WBS dictionary into P6 Project. The best way is to use the excel XER parser & builder. You can create a WBS dictionary for a project using this tools. But you need to learn how to use it first. See link for your reference. How to Import WBS using excel XER parser
