Excel spread sheet to read XER files
Ron Beechey
User offline. Last seen 5 years 16 weeks ago. Offline
Looking for excel spread sheets or the likes to read xer files and produce curves and any other helpful information.   I have one "01-XER-READER" which I found very good but wondered if there was a actual curve that could be added.  There may be also an update which I have not been able to find.   Always good to not reinvent the wheel if someone has already worked on something.
Joel Roberts
User offline. Last seen 1 year 1 week ago. Offline
Hi Ron.
You can use ScheduleReader to read XER, XML or XLS files.
You can see S-Curves, Histograms, compare baselines, trace predecessors and succesors, filter, group, sort through data and even create reports from the data inside the schedule.
A free 15-day trial of the application can be downloaded through the website mentioned above.
User offline. Last seen 1 week 4 days ago. Offline
yes project tracker can do that
David Kelly
User offline. Last seen 2 years 48 weeks ago. Offline
Bryc,
Easy. Use Project Tracker.  Reads the database, lets you take baselines, makes "s" curves with the data range table underneath.
bryc ali
User offline. Last seen 2 years 39 weeks ago. Offline
How we can read the data base directly to produce S curve ?
David Kelly
Project Tracker does everything for a couple of hundred pounds. Even reads the database directly so you can produce real "S" curves without creating a second data source.
