Exporting Problem from Primavera to Excel
K
Kien Dinh 👤 Member for 6 years 11 months
Dear All,
To day I have tried to export a P6 file to Excel format but unlucky it appeared to be failed, the dialog box said that: "Cannot export while sub-unit for duration/time are enable". I have tried in several ways to solve it but still failed. Anyone know this and advise me would be much appriciated.
K
Dear sỉ,
Trying this way has solved the issues.
 DQK
Z
go to edit users prefernces
then on tthe time units tab under Units format uncheck Sub-unit
and also under Durations format uncheck sub-units
K
Dear Zoltan,
Thank for the reply. I have verified both the Window and P6 for decimal and digit. After that, I tried to export P6 again but it still didn't work. Perhap the decimal and digit was not the cause for the exporting problem.
[[wysiwyg_imageupload:6885:]]
Z
Issue is caused by the Windows Regional Settings having an inconsistent Decimal symbol and Digit grouping symbol then the Decimal Symbol and Digit grouping symbol in P6 Professional.
To ensure that Decimal symbol and Digit grouping symbol for both P6 Professional and the Windows Region and Language settings, under Customize Format, match and are consistent with the desired currency please do the following:
Make sure that these match
For the Windows OS Region and Language settings:
  1. Launch the Windows OS Control Panel
  2. Select 'Region'
  3. Select 'Additional Settings'
  4. Select the 'Currency' tab
  5. Review the 'Decimal symbol' and 'Digit grouping symbol'
For P6 Professional
  1. Access P6 Professional
  2. Select 'Currencies' under the 'Admin' menu item
  3. Review the 'Decimal symbol' and 'Digit grouping symbol'make sure that
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
