Importing a Microsoft Projects with Project Actuals Into P6 to compile a baseline
Eric Gonzalez
User offline. Last seen 5 years 15 weeks ago. Offline
I have been given a project that has actuals in Microsoft Project. I need to pull out the baseline from this into p6. What would be the best solution once inported into p6? Would I need to uncheck the finish and start section on the actuals? There are about 1200 activies and another alternaitve would be helpful.
User offline. Last seen 6 days 13 hours ago. Offline
yes that is correct u have to run a couple global changes to de-staus a project and also change the data date
Eric Gonzalez
Thank you all for the useful information. I have found how to uncheck start and finish statuses. I initially did a globacl change to correct this.
User offline. Last seen 19 weeks 7 hours ago. Offline
https://www.planacademy.com/how-to-remove-actuals-from-primavera-p6-schedule/
Please be reminded that - "... there exists a common trend with Microsoft Project users which is quite common across the world. These schedulers simply ignore the requirement for proper planning logic and insert negative lags to achieve a quick programme with minimal activities".
https://www.gbaprojects.com.au/uploads/files/whitepaper_-_poor_planning_negative_lag.pdf
You might need to adjust the logic of MSP schedules.
take it into p6 and destatus the project I sent u an email here I can send instructions on how to de-status
