How to revise budget unit without changing the current duration???
14 replies [Last post]
Ali Reza
User offline. Last seen 7 years 19 weeks ago. Offline
I have a question, please help me.
I revised durations in a schedule at P6 regardless of remaining units and remaining duration and submitted to HOD.
The original budget available and duration type already defined by previous planner is fixed duration & units.
The client asked to revise the budget and add the revised budget in P6 and then from P6 take the weekly planned budget.
How can I revise the budget unit without changing the duration and date?
If I add the remaining units, the remaingin duration will change, so current completion date also will change.
Please support me how to revise the budget units without affecting claimed completion dates and how to extract weekly budget unit from p6, same what we defined in excel in terms of weekly man-hour histogram????
User offline. Last seen 1 week 5 days ago. Offline
just filter by wbs and on the left use the + and - to roll up and to unroll the procurment activities also in the gropuing select show grand totals
Ali Reza
It is requested to show only procurement activities in P6 and all other ativities should be shown in summary level (wbs level).
I filtered but summary of other activities are shown without date and without gantt chart bar.
Please help me in this case.
filter for ALL activities add a column look under the General Category and bring activity TYPE to the right
on the first activity at the top in the activity type column change it to fixed duration and units/time
now do a fill down in that column
now go to the Projects directory
make sure that your project is highlighted
click the defaults tab and select fixed duration and units/time
done
Ali Reza
Is any body can explain me about activity code and how to define new project activity codes?
I want to define activity codes to filter easily accordingly.
Ali Reza
How to make Duration % complete equal to physical % complete in P6?
Then, whenever we enter physical % complete manually, the duration % complete also updated same.
Ali Reza
Thank you very much.
I got it.
Frank Douglas
User offline. Last seen 8 years 8 weeks ago. Offline
I have no idea of it.
change your duration tyeps to fixed duration & units/time
Ali Reza
THANK YOU FOR YOUR ANSWERS.
I HAVE ANOTHER QUESTION IN P6?
I added I added remaining unit for an activity, after re-scheduling the start & finish date will change without respecting to predessor. When I remove the remaining unit, It follows the relationship.
Could you tell me how to avoid changing of dates in this situation?
Ali Reza
got to tools Global change and add a new global change
where  physical percent complete is greater than 0
then duration % complete  = physical % complete
then execute the global change press change
then committ chnages
do this afret each update after inputting ALL physical % completes
and before you calculate the schedule
Ali Reza
Hi to every body,
When % complete type is physical, how the remaing will be calculated by P6?
Remaining duration I mean after changing of data date and  rescheduling???
Zulham Julio
User offline. Last seen 8 years 16 weeks ago. Offline
excuse me sir, i,m newbie in this forum. how can i post a question in this forum? thank you
change the duration type to fixed duration & units/time for all activities you can add that column duration type then do 1 then do a fill down
