Airport Construction schedule
Alaa Al haj
User offline. Last seen 8 years 21 weeks ago. Offline
Hi All,
who can share with us basic things to consider we you plan for Airport construction
and if possible share typical schedule shows major activities
thanks
User offline. Last seen 2 weeks 1 day ago. Offline
there is a lot to consider
Alaa Al haj
Thanks Zoltan for your points
I am checking the documents and requirements and will keep attention to your points
appreciated
BR
Alaa
is this a new airport or a renovation of an existing airport ?
is there road work ramp work enplaning and deplaning ? do you have to keep these active during construction ?
is there a phasing plan ?
how many gates can you take down at a time ?
are you building any additinal runways ?
do you need swing spaces for exisrting tenenats ?
are you building a additinonal fuel tank farm ?
are you installing a gylcol recovery system ?
are you building a de-icing area ?
are you installing in ground fuel tanks at the gates ?
is there taxiway work ?
is there runway work ?
is there loading dock work  ?
is there air traffiic control tower wok as well as ground control tower work ?
how long does it take for construction personell to go through the badging progess to get AOA access ?
how are you going to get the craft onto the AOA area ? bus ?
are there seperate gates for the craft as opposed to airport employees ?
are you bringing in concrete or do you have an onsite batch plant ?
do you have a deciated haul road through the airport as well as a stock pile area ?
are you working in an international arrivals area if so do your people need to be finger printed ?
shall I go on ?
