Project Calendar not showing in Default calendar Selection Pane
Harry Angell
User offline. Last seen 5 years 36 weeks ago. Offline
I have a project which I created 2 project level calendars for, but even after summarising the project I can't select either calendar to set it as the "Default Project Calendar".
When I go to set the Default calendar it doesnt show any of the project Calendars I have created (I created 2). I have deleted the summarization, and re-summarised but no luck.
Can anyone help?
Sadirov Sokhib
User offline. Last seen 8 years 10 weeks ago. Offline
Hi everybody
I got problem with setting up starting day of the week for calendar. As default day it is showen friday but I want to make it monday. I tried to select at admin preference part, but button is not working. How to fix?
please help guys
User offline. Last seen 23 weeks 6 days ago. Offline
ok at the project level make sure that your project is highlghted
then in the defauls tab on the right click on calendars if you dont see the project calendar click on the upside down triangle and select Display Project calendars
under admin then security profiles
highlight the global profiles then under profile name make sure that ALL of the Has Privilege boxes are checked
highlight the project then under whatever profile si your default profile name make sure that ALL of the Has Privilege boxes are checked
Harry Angell
Hi Zoltan,
I have tried setting default calendar from projects window but its not showing the project calendar when you set the category to 'Project calendars'. I can see global calendars but not Project. I am set as <Admin Superuser> and I can't see any additional settings relating to Project calendars that can be enabled so I assume I have the rights, am I missing a setting?
When you go to the projects directory make sure that your project is highlighted and you shoudl be able to select the calendar there are the default calendar to use of your project.
Also make sure that you have the admin security rights to do so.
