converted PowerProject programme mixed duration formats
Andrew Owenson
I have converted a Powerproject file to msp, however the duration & total float formats are mixed, ie some are "15 d" and some are "3 w". I cannot see where you can change them all to days??
Andrew
Tom Boyle
User offline. Last seen 1 week 2 days ago. Offline
Andrew,
If you are running MSP 2010+ and are comfortable with vba, you can drop this into a module and run it:
Sub DurationDays()
    Dim t As Task
    For Each t In ActiveProject.Tasks
        t.Duration = Application.DurationFormat(t.Duration, pjDays)
    Next t
End Sub
(Method is supposedly different with earlier versions, but I have no way to test.)
Otherwise, you may be stuck with manually changing the durations, perhaps with a little clicking and dragging.
Good luck, tom
