VBA - Deleting Tasks (criteria based)
Rob Garbutt
User offline. Last seen 7 years 26 weeks ago. Offline
Hi all, I'm looking for some help using VBA to delete rows in an MSP I own. There aretasks in my plan labelled as either "C" or "I" (as in Client or Internal) using a custom "text23" column. I'm currently having to manually delete, line by line those labelled "I" in order to send my client a sanitised version of the plan.
I'm not quite at the stage yet to write my own VBA, but I'm certainly able to administer it. does anyone have an idea as to how the code to perform this task should look?
Rob Garbutt
Rob Garbutt
Thanks Tom, this is really useful.  Strangely I appear to have to run the macro a couple of times in order to delete all "I" tasks, but it beats doing it manually that's for sure! (my plan is 5k tasks long).
Also I agree with your advice regarding this method being slightly risky, and in all honesty I don't see any reason to hide anything from the client anyway, but I aint the boss!  Ultimately I'm untertaking this task manually regardless, so I've ensured that no logic will be broken in the process, and now it's automated it can be done much quicker!
Thanks again,
Rob
Tom Boyle
User offline. Last seen 11 weeks 6 days ago. Offline
Hi Rob,
Here's a simple procedure that does what you suggest for a simple project I tested it on.
Sub DeleteInternal()
Dim t As Task
    For Each t In ActiveProject.Tasks
        If Not t Is Nothing Then
            If t.Text23 = "I" Then t.Delete
        End If
    Next t
End Sub
 Personally I would never use this kind of hammer on one of my schedules - without very serious review and confirmation of the "I" codes.  You are liable to break some logical or resource link, and the client will not be happy when they open your schedule, calculate it, and get different results than you have. You might also consider developing a routine that simply obfuscates the names of the tasks, leaving the logic and other data untouched. Good luck, tom
