VBA VBA VBA
6 replies [Last post]
Andrew Owenson
User offline. Last seen 1 year 42 weeks ago. Offline
I have a filter which selects ceratain activities. Can anyone advise on how to write a macro which takes the resultant activities from this filter and colour the bars say green.
Many Regards
Ab=ndrew
Andrew Owenson
Niek
Many thanks for your help, it has set me on the correct path.
Andrew
Andrew Owenson
Darren
What Im after is an additional bar type alongside the two bars in a critical path view ie, critical = red 0TF blue for activities with Tf bigger than 4days and a near critical activity with TF less than 4. I have added this bar as a flag and what I would like to be able to do is have the chart update automatically to show these bars.
Andrew
Niek Zonneveld
User offline. Last seen 11 weeks 1 day ago. Offline
Andrew,
I guess it won't automatically select the tasks you've filtered (see line in bold), so you loop through 1 active line only.
It's probably safer is to use the filter criteria (hard coded) in the loop itself. (less flexible, probably but...)
H.T.H.
Niek.
'set the flag field for the selected task
FilterApply Name:="Near Critical"
For Each jTask In ActiveSelection.Tasks
     If Not jTask Is Nothing Then
        jTask.Flag20 = "Yes"
    End If
Next jTask
Darren Kosa
User offline. Last seen 8 years 5 days ago. Offline
Hi Andrew,
If you're already using Filters for your macro, have you thought about just formatting a new Task Bar using Bar Styles?
Saves things getting overly complicated by going down the VBA route.
Darren Kosa
Andrew Owenson
Niek
Thankyou for your interest.
This is what I have done.
I am using the field flag20 as my yes/no - I have set a bar in the view to be green if flag 20 is yes. I first clear the flag20 field - that works. I then run a filter - that works. But wehn I run the next bit where I want the filtered bars flag20 filed to be yes it only makes the first bar yes and does not change any more. Any ideas.
Andrew
Sub Colourfiltergreen()
' Macro Colourfiltergreen
' Macro Recorded 13/09/11 by Andrew Owenson.
Dim jTasks As Tasks
Dim jTask As Task
'clear the flag field
For Each jTask In ActiveProject.Tasks
        jTask.Flag20 = "No"
    End If
Next jTask
    End If
Next jTask
FilterApply Name:="All Tasks"
End Sub
Niek Zonneveld
Andrew,
I would go with a structure like below.
For all tasks that meet your filter criteria you have the field "Marked" set to "Yes" by the macro.
The next step is to create a view where the bar for a 'marked' task is shown in a different color.
HTH
Niek.
Sub Color_line()
    Dim t As Task
    Dim Blank_Line As Integer
'This macro loops through all selected lines and changes the color based on the line meeting certain filter criteria.
    For Each t In ActiveSelection.Tasks
        If t Is Nothing Then
            Blank_Line = Blank_Line + 1
            ElseIf filter criteria Then
            Tsk.Marked = "Yes"
Else
        End If
    Next t
End Sub
