Microsoft Project 2013 and the Look Ahead Filter
6 replies [Last post]
Emily Foster
User offline. Last seen 3 years 4 weeks ago. Offline
Here's a great tip on how to create a Look Ahead Filter in Microsoft Project http://ow.ly/wLBo300pa1D
Brian Sheils
Emily
Your formula certainly works fine and I did not doubt that it would not - I did use it for my project and I get a blank project - just like your 4 week lookahead - when I click on that it returns a blank - although you have no formula for that I believe anyway I used your formula which works fine but not in my Project - I need to go through and see where I am going wrong but again Thank you so much for the help and formula - I am doing something wrong that I need to remedy
Brian
Brian Sheils
Thanks Emily I will certainly give it a go and Thank you for this - fingers crossed as I could do with using it at the moment
Brian
Emily Foster
Hi Brian,
If you go to the bottom of the article, I've just added the Microsoft Project file that I used. Hopefully this will help.
Tom Boyle
User offline. Last seen 18 weeks 5 days ago. Offline
Brian,
For a response other than "double check harder," you need to be more specific.
What region are you in (determines whether to use commas or semi-colons)?
What (exactly) is the formula you are entering?  In what field?
What specific errors are you getting?
Needless to say, is your installation fully up to date?
Brian Sheils
HI Guys
I have tried this formula in MSP 13 and it does not work - it brings back errors even though I have double checked it still no good - so either I am missing something or the formula is presented wrong - possibly more my fault I assume at this stage
Please advisew anyway
Thanks Brian
