Project Summary show only one fourth duration of activity
13 replies [Last post]
Kumar Baiju
User offline. Last seen 11 years 24 weeks ago. Offline
Hi Alll
      I have one question about the actual duratin in MS project-2003. I am using 24 hous calander for my prject. when i updated my actual duration E.g. 10 hrs then in project summary it shows only 2.41 hrs. similiarlr when 20 hrs it appears 4.83. I cannot understand why in summary it comes only nearly one fourth duration
4.83 Hrs 2.41 Hrs
20 Hrs 10 Hrs
Kumar Baiju
Dear Rafael
         I have seen the Video. That is for Task summry not for the Project summary. I can do also for the task summary but cannot for the project summary. If any other method you have please reply me
Thanks\\
KBJ
User offline. Last seen 21 weeks 1 day ago. Offline
Kumar Baiju
Dear Rafael
            It is the summary and not editable. please suggest how can i edit it.
Click where you see None (at Summary Task) and change it to 24 hrs calendar and let me know.
Kumar Baiju
Dear Rafael
               In my project Calculation mode is automatic and calendar in Task information & project infromatin is same i.e 24 hous.
Regards\\
KBJ
238
Where the calendars different?
If different and you changed the calendar did you run a schedule run?
I use MS Project rarely but because use MS Project 2010 I setup all task mode in automatic.
Kumar Baiju
     It does not solve my problem
KBJ
Kumar Baiju
KBJ
Try inserting a column to display Task Calendar, if it differs at a Summary Bar change it to 24 hours and let us know what happened.
Kumar Baiju
Daer Alexandre
          Thanks for your reply. But i have assign in both fiel 24 hous calendar.
Kumar
Kumar Baiju
Daer Alexandre
Kumar
